how to clean an idle control valve
just disconnect the ISV and spray carb cleaner into both holes (ooh er!) Leave it in for as long as you can stand and then tip it up unto your mum's clean kitchen floor. Repeat until there is no mucky stuff coming out - just lovely clean fluid. Job done. If you can be arsed, try to hold the valve open ( by rotating the drum inside) to give it a more thorough seeing to.
