ian c 1 Posted February 2, 2017 Report Share Posted February 2, 2017 Ok so coolant light came on today so checked coolant leval all ok, then noticed that the blowers wasent getting that hot, so ok so gathered thermostat needs replacing as car isn't over heating, then i I noticed that cooling fans have stayed on and there still on, what can can that be? Quote Link to post Share on other sites
Philly-R6 26 Posted February 5, 2017 Report Share Posted February 5, 2017 It could be a faulty coolant temperature sensor? There is a good explanation of the VR6 cooling system on the Corrado Forum ( http://the-corrado.net/showthread.php?38925-The-definitive-VR6-cooling-guide ) well worth a read to get an understanding of how it operates. There is a sensor on the thermostat housing driving the temperature gauge in the dash. The other sensors on the thermostat housing, along with the sensor on the radiator inform the Fan Controller to operate the multi stage cooling fans. You can do some tests on the sensors, as documented on the Bentley Publishers article on Gauge and Instrument Testing ( http://www.bentleypublishers.com/tech/vw/bentley.vw1301.testing.htm ) Understand the problem before shelling out your hard earned dosh! Quote Link to post Share on other sites
