TheFryingDoctor 2 Posted January 15, 2017 Report Share Posted January 15, 2017 Hi guys can anyone shed some light on a few issues for me please.1 what are the better bushings polybush or powerflex or is there no difference found a kit for £280 from polybushthat basically covers all the essentials apart from steering rack and arbs but want to put the eibach arbs on anyway and steering rack and dogbone bushes are a few quid but i like the look of as it has a slight taper on the ends and have read without the taper it can cause squeaking is this true or will grease sort that out when installing or have they just been put in to tight2 my fuel pump is making a slight whining noise every now and then have the AUE engine code and I'm lead to believe i can use a aftermarket pump rather than a genuine vw pump or is there a better alternative i can go for maybe a walbro in tank pump ??I'm aware its not going to make a bhp difference but thought id ask if anyone has used anything different ? 3 who is recommended to map out the evap so i can simplify the vacuum lines etc under the bonnet Any help or info would be mint Link to post Share on other sites
TheFryingDoctor 2 Posted January 16, 2017 Author Report Share Posted January 16, 2017 Can anyone advise or is it a case or trial and error ? Link to post Share on other sites
