VR6OC News Bot 30 Posted January 10, 2017 Report Share Posted January 10, 2017 The new modified WRX and STI participated in the exhibition in Detroit. Their performance remains the same only the outlook is changed. They now look sharper with a several external modifications. The front suction system now has a bigger opening hole. It also has better LED lights for better ride experience at night. The interior of the cars is also modified and now they look better. The multifunctional 4.3 inch display is replaced with a 5.9 inch display. The sound isolation is improved so when you are inside you can barely hear the engine. The new modified STI has a better handling. Driver Control Center Differential now uses electronic control system while the standard STI used a mechanic actuator. The Brembo breaks are also improved with six-piston front calipers and two rear calipers. There are ventilated discs on all four wheels. The WRX also has to be better for handling. It comes with a new synchronized transmission with modified RPM Levels, and Subaru claims that the new servo gives the driver better driving experience. View the full article Link to post Share on other sites
