leebee 0 Posted July 4, 2016 Report Share Posted July 4, 2016 Hi guys I know it's probably in here but can't find it So I want to turbo my 2.8 12v Looking for 300-400bhp with out splitting the head . JUst bolt on I just need help on what turbo to use and injectors (440 seams popular) And how people have done management Cheers guys Link to post Share on other sites
RBPE 199 Posted July 5, 2016 Report Share Posted July 5, 2016 Holset HX35 seem popular for a cheaper journal bearing alternative, dealt with a few that have gone that route - rest of the turbo and DIY guides are stickied above in the forum and most of what you need there. I'd say Stealth for a map and yep, 440 green giants or whatever they are calling them nowadays are good - just make sure you get proper bosch ones. As for 400hp, without lowering compression you'll probably have to spend a lot on the mapping, maybe a 7/8 psi tune on stock but above that - very fine tuning or knock will arise due to high comp - usually cheaper getting a spacer plate! Stealth also do a bolt on for these for 350hp ish I believe - depends on level of DIY you wanna do! Link to post Share on other sites
