VR6Treg 0 Posted March 21, 2019 Report Share Posted March 21, 2019 (edited) Since you bring up the immo aspect I ordered a kessy. I will clone it and use it as a spare. I ordered a used on with the same part number. Do you recommend any tools for ecu and kessy cloning? I found a post where the guy used carprog to clone the kessy. http://www.codecard.eu/carprog/software/programmer/s4-7-kessy-tool-a8-toureg-phaeton-cayenne-pin-code-reader/prod_167.html For ecu flashing I will use galletto and nefmoto flasher. I also have a genuine ftdi obd cable. If I can do without boot mode it's be great but i was told I will have to open both original and spare ecu to clone. Edited March 21, 2019 by VR6Treg Link to post Share on other sites
RBPE 198 Posted April 2, 2019 Author Report Share Posted April 2, 2019 Yeah something like carprog should work, depends on tools/ecu, the need to desolder etc, there should be a few threads about online that tell you, it can really vary between ecu's and flashing tools what data you get or can manipulate on these, as well as which C166 ecu you are using given the variance. Link to post Share on other sites
