The definitive remapping thread
Since you bring up the immo aspect I ordered a kessy. I will clone it and use it as a spare. I ordered a used on with the same part number.
Do you recommend any tools for ecu and kessy cloning?
I found a post where the guy used carprog to clone the kessy.
http://www.codecard.eu/carprog/software/programmer/s4-7-kessy-tool-a8-toureg-phaeton-cayenne-pin-code-reader/prod_167.html
For ecu flashing I will use galletto and nefmoto flasher. I also have a genuine ftdi obd cable.
If I can do without boot mode it's be great but i was told I will have to open both original and spare ecu to clone.
Edited by VR6Treg
Yeah something like carprog should work, depends on tools/ecu, the need to desolder etc, there should be a few threads about online that tell you, it can really vary between ecu's and flashing tools what data you get or can manipulate on these, as well as which C166 ecu you are using given the variance.
