coullstar 2 Posted June 20, 2005 Report Share Posted June 20, 2005 I have got myself a second hand cone filter and I know you are better with the BMC etc but I cannot justify spending that much on a filter. What I would like to do is first of all have a so called cold air pipe that direct air from the front of the car onto the filter. What have people done in the past. Pic would be good.I will probably look at making a BMC style filter in future i.e. locting the filter where the carbon canister is. Has anybody done this before? Does my air-con have any impact on this? Link to post Share on other sites
vr6freak 3 Posted June 20, 2005 Report Share Posted June 20, 2005 basically the cold air intake pipe go down via where the carbon canister was located. ( you need to block off one of the pipes and keep the other open, do a search in previous threads ) and the the filter goes on the end of the cia pipe. between the front bumper and the under arch trim to keep the rain etc off it. Link to post Share on other sites
coullstar 2 Posted June 20, 2005 Author Report Share Posted June 20, 2005 I seem to remember that there is a plastic pipe a couple of inches in diameter that is screwed to the front of the airbox. Surely this will direct air onto the filter as it is still there when the airbox is removed. Link to post Share on other sites
