mattvr6 133 Posted September 24, 2015 Report Share Posted September 24, 2015 The vacuum plunger unit on the side is stuck down when running the vac pipe us collapsed as well holding it down, had any one had this issue or any ideas? I'm fussing should be closed then opens when you gun it??Thanks Link to post Share on other sites
RBPE 199 Posted September 25, 2015 Report Share Posted September 25, 2015 Sounds like either there is a vacuum leak - worn parts or it's not charging the solenoid which the ecu does speed and load dependent. It is in the power position at idle then switches to the torque position as you put your foot down then changes back to power as you pass peak torque so if it's not working then it's likely stuck in the power position. Replace all vacuum related parts first, if not then it's either a knackered solenoid or somethings happened in the ecu, codeworded it off. Link to post Share on other sites
mattvr6 133 Posted September 26, 2015 Author Report Share Posted September 26, 2015 I'm going on solenoid vac pipes are all good Link to post Share on other sites
