crunch into reverse
the vr6 seems to crunch into reverse from cold however once warm its fine, only occasionally catching slightly.
gearbox has had fresh 75w90 synthetic oil but still getting the crunch from cold
possibly related - it has clutch judder so pressure plate/ friction plate is on the way out
any ideas?
Do you have the full range of pedal throw?
When first started, on the vr, I can lift the clutch pedal 40-50mm. The pedal firms up a bit after allowing me to fully engage the clutch when selecting gear, I think it's master cylinder on mine causing the bother, would that be a possible for yours?
