faigolfgti 0 Posted October 17, 2014 Report Share Posted October 17, 2014 Recently my vw vr6 can't start the engine so the vag1551 detected fault code G28(crank snesor)no signal to ecu,replace to brand new crank sensor my vr6 engine still cannot start check again with vag1551 same fault code G28,PLEASE HELP! Link to post Share on other sites
alcohol 0 Posted October 18, 2014 Report Share Posted October 18, 2014 Check the ignition coil if it has cracks, they always put an fault code on the crank sensor when its not started when your checking the codes Link to post Share on other sites
faigolfgti 0 Posted October 21, 2014 Author Report Share Posted October 21, 2014 Already replace brand new coilpack,check the crank sensor G28 wiring all the way to ECU is fine and conected ,so i am wondering is it the ECU FAULT?Any fault code for BAD ecu? Link to post Share on other sites
