In the mornings only or when havent use car several days
Car starts fine but no throttle response/ no power. Sometimes stall when havent use car several days. Lasts only 1-3min after starting
rpm go over 1000 with cold engine but it suddenly drops to 700-800, usually on other car its goes down slowly
vagcom codes
Control Module Part Number: 022 906 032 B
 Component and/or Version:  MOTRONIC ME7.1     V006
          Software Coding: 00132
           Work Shop Code: WSC 31440
5 Faults Found:
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
       P1127 - 35-10 - - - Intermittent
17537 - Fuel Trim: Bank 2 (Mult): System too Rich
       P1129 - 35-10 - - - Intermittent
17545 - Fuel Trim: Bank 1 (Add): System too Rich
       P1137 - 35-10 - - - Intermittent
17547 - Fuel Trim: Bank 2 (Add): System too Rich
       P1139 - 35-10 - - - Intermittent
17551 - Load Calculation Cross Check: Upper Limit Exceeded
       P1143 - 35-10 - - - Intermittent
coolant temp sensor looked fine if it was right block but air intake sensor show 29´C and outside was 15´C (it has new maf)
also Group 001, O2 sensor before cat were -20% to -15% on idle with 63´C engine temp, vagcom normal values (-10 to 10%) but maybe engine temp was too low and these values just show that its running rich
Golf iv, vr6 150kw, 4 motion, 2000
Edited by silvereik
