Now I'm. Ploughing through the bodywork side of the mk2 vr I'm wanting to start on making the engine run a little smoother and give it a bit of probably a long overdue service and clean out generally..
My question is what's the best way to give the coolant system a good flush out? Can I run the engine whilst having a hose maybe into the header tank to circulate the water while I have a hose off the bottom of the radiator??
Or is the best way to just drain it all off via a bottom rad hose then refill and drain again a couple of times until I'm happy?
Advice would be much appreciated on what yous have done etc
jimmys oakvr
