what to lookout for
hi im looking at a mk3 vr6 tomo which has had a engine rebuild costing nearly £1k he has sent me pic and list of parts bought for it , the outside is clean with no rust so he says , but is there any trouble spots to lookout for cheers j
Check the underneath for corrosion and rot, ABS lights, pull the cover of the abs blanking to make sure the light hasnt been bodged with black tape to hide a fault. PCV valve splits near the block. Listen to the timing chain for rattles on tickover.
Generally sound cars, with rust and rot being the main points.
