Poriordan 97 Posted February 5, 2014 Report Share Posted February 5, 2014 I started my vr6 turbo the other day and she runs fine I tried to do the same the next day and it won't run it starts briefly then cuts out and the oil light flashes any ideas on what could've happened oh and yes it has oil :-) Link to post Share on other sites
Jakeyb 23 Posted February 5, 2014 Report Share Posted February 5, 2014 the two things could be related to a wiring fault , have you plugged into diagnostics to see if it throws a code up? tried the basics of taking the negative off the battery for 10 mins and trying again .. checked all wiring n plugs? did you give it grief and then park it up or was it allowed to cool down properly and stuff? Poriordan 1 Link to post Share on other sites
Poriordan 97 Posted February 5, 2014 Author Report Share Posted February 5, 2014 It's was only run up to temp then sat for couple of mins and I'll have a butchers at the sensors and wiring tomorrow cheers ;-) Link to post Share on other sites
Jakeyb 23 Posted February 5, 2014 Report Share Posted February 5, 2014 no stress , if you were closer id say id have a look but thats a long way to have a butchers! it could also be an imboliser issue if it starts but cuts out almost instantly .. plus if its rained id check the fuse box's Poriordan 1 Link to post Share on other sites
Edward Clark 3 Posted February 5, 2014 Report Share Posted February 5, 2014 Never trust a oil light. Put a gauge on it. It could be one of two things going on. Most likely it is the oil pressure switch located on top of the oil filter housing. They do go bad once in a while and when the light comes on it cuts out your fuel pump to protect the motor from people that ignore dash lights. Option two, oil pump. It could be worn out and not producing enough pressure at idle. Option three. Clogged oil pump pick up tube or screen .Its not that hard to pull the oil pan and check. How many miles do you have on the motor ,and how many since the turbo install? Sent from my iPad using Tapatalk Jakeyb, Poriordan and michael5556 3 Link to post Share on other sites
Poriordan 97 Posted February 6, 2014 Author Report Share Posted February 6, 2014 Ok guys thanks for the help it was an immobiliser fault I had a bad battery witch caused the fault to stay on the new battery but soon as I disconnected the negative for 10 mins or so then reconnected she fired straight up thanks all the same ;-) Marneus 1 Link to post Share on other sites
Jakeyb 23 Posted February 6, 2014 Report Share Posted February 6, 2014 long as shes working again thats all that matters! Link to post Share on other sites
