I think Liqui Moly do a product for this that is sprayed into the evaporator. I have the same problem with the Climatronic on mine.
I took it to VW and they cleaned the system out. It lasted for about 6mths. I changed the pollen filter as well before but that really doesn't make much difference. Depends where the mold is and how best to treat it to really get rid of it and the problem.
Maybe a specialist Air Con plac would be able to help out!
"You should leave the a/c on all the time, even if not using it to cool the car. You should also turn the system to full cold for ten minutes once a week – even through the winter if you can – in order to circulate refrigerant which contains lubricants for the system and its seals. Then switch to full heat through the same pipes to thoroughly dry them out. This also blows out any moisture in the ventilation passages where mould and bacteria might be accumulating."
Taken from here www.honestjohn.co.uk
Look for this non ebay ...
Anti Bacterial Deoderiser
If any customers complain of 'nasty smells' when the air conditioning is on, simply spray this foam like anti bacterial deoderiser into the heater/evaporator box (under the dashboard). The can is supplied with an applicator tube. This tube is used if you find it difficult to gain access to the heater/evaporator box. e.g the tube can be used up the evaporator drain
My cars got climatronic so i haven't got an a/c button, i noticed the aircon compresser runs all the time hot or cold unless i press the "Econ" button, which i usally do
I've always wondered whats the point in it being on when it blowing hot air ?
I've always turned it off to save a bit of petrol and power.
Thanks for the help guys :)
Bee...
