Hi guys, just a quick 1. I fitted my poly bushes at wknd and when i tried to refit my subframe the mounting holes through the rear bushes do not line up with the actual chassis holes. The only way i can get them to fit is to remove 1 of the little metal spacers that is supplied with the kit. I dont want to remove spacer as it stops bolt moving around. Any1 else had any dramas an overcame them ??
Cheers
