Hi gents, got myself another vr but currently trying to put her right, done a service on her, its a 1994 6pin Maf jetta vr6... pics to come.
Problems:
00258 - Solenoid Valve 1 (N88)
36-00 - Open Circuit
00260 - Solenoid Valve 2 (N89)
00262 - Solenoid Valve 3 (N90)
00264 - Solenoid Valve 4 (N91)
00266 - Solenoid Valve 5 (N92)
00270 - Solenoid Valve 7 (N94)
00518 - Throttle Position Sensor (G69)
16-00 - Signal Outside Specifications
00281 - Vehicle Speed Sensor (G68)
03-00 - No Signal
00532 - Supply Voltage B+
35-10 - - - Intermittent
00638 - Engine/Transmission Electrical Connection 2
03-10 - No Signal - Intermittent
30-00 - Open or Short to B+
01257 - Idling Speed Stabilization Valve (N71)
31-00 - Open or Short to Ground
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
00515 - Camshaft Position (Hall) Sensor (G40)
Any help on where to start looking to correct all these errors?
To ad the motor runs VERY hot, oil is 102 and water guage runs to 110 before the fans come on, i know something is very broken just not sure where to start.
i have serviced the car with new, oil filter, oil, spark plugs and air filter.... still need to do the fuel filter.
Appreciate the help gents!
