Relocating the battery to the boot
Tried to draw a diagram for the relocation of the battery to the boot... I think the positive side of the battery is ok but not sure about the negative side...
Where does the negative wire from the battery to the back of the fuse / relay board attach, route etc...
Help would be appreciated
There wont be a main one, it will just be chassis ground so anything listed as going to earth will only have to be the thin gauge wires, rather than routing to one big main one.
If I was doing a battery relocate I would do the same for the pos and for the earth would bolt the engine/gearbox ground to the chassis leg where the tray was then just put a new mounting post like you did in the boot. Minimal messing around then, the less new stuff you change the less opportunity for something to mess up :)
Oh....!! And the earth from the coolant fan can also just attach to the "new" made body earth on the chassis leg ( the wire that would usually run from the coolant fan to the neg terminal on the battery)
Cheers again ;)
