rsweeney 40 Posted April 5, 2013 Report Share Posted April 5, 2013 I am running dimpled and grooved ebc disks with green stuff pads on the front and I have noticed how poor the braking is when cold.Im guessing this will be down to the green stuff pads ? If so I have read that you cant really go wrong with oem pads but for an upgrade what about the ferodo ds2500 pads are they a straight forward fit ? only problem im having is that they don't have the type with built up wear indicators that I need do they ? Rich Link to post Share on other sites
Lukey. 381 Posted April 5, 2013 Report Share Posted April 5, 2013 If you need a wear sensor wire you can just solder the wires together from one cut off any pad with the same plug to form a circuit, they are a closed loop system so would bypass the pads indicator. Link to post Share on other sites
