Repurr 3 Posted March 19, 2013 Report Share Posted March 19, 2013 97/98 MK3 Vr6 HighlineHi,When washing my car, I noticed the rear driver’s side window was just open. I tired to close it, the motor worked when I pressed the button but nothing happened. When I pressed it to go down it went down and will now not go up, the motor is working both going down and up.Any ideas as to the cause of this?and How do you remove the inner door panel to investigate the inner workings of the door as from an initial look, I can’t figure how to do it?Thank you Link to post Share on other sites
Nex 17 Posted March 19, 2013 Report Share Posted March 19, 2013 My guess would be that one or bother of the little plastic clips that hold the window have broken buddy, It is a farily easy job to replace them though. Link to post Share on other sites
Repurr 3 Posted March 19, 2013 Author Report Share Posted March 19, 2013 Thanks for that.How do you get into the door to check that and also where is the best place to buy the clips (in the UK) Link to post Share on other sites
Lukey. 381 Posted March 19, 2013 Report Share Posted March 19, 2013 Take the cover off the inside handle, undo the screws and pop the perimeter off the. It should just lift straight off. Link to post Share on other sites
