spadam 7 Posted November 24, 2012 Report Share Posted November 24, 2012 Right if i was to fit a spacer plate and while evrythings apart replace the chains and tensioners would it fit together. Ie would the chains fit with the extra few mm from the spacer plate? Chains probally dont need doing but just a thought while everythings apart. Link to post Share on other sites
UnitedMotorsport 55 Posted November 24, 2012 Report Share Posted November 24, 2012 Yes. Link to post Share on other sites
spadam 7 Posted November 25, 2012 Author Report Share Posted November 25, 2012 Excellent just what i needed to know Link to post Share on other sites
bungy 2 Posted November 25, 2012 Report Share Posted November 25, 2012 Just remember to allow for the spacer when putting everything back together. Had me scratching my head for a bit. I have a Bentley manual if you need to check anything. Link to post Share on other sites
spadam 7 Posted November 25, 2012 Author Report Share Posted November 25, 2012 Cheers Mark. So i assume the timming would like around 2mm out? Link to post Share on other sites
bungy 2 Posted November 25, 2012 Report Share Posted November 25, 2012 When I did mine I marked everything and after the spacer went in it was all slightly off. You just have to check it is off in the right direction and go with it. Link to post Share on other sites
