drivers side window
My golf drivers side window is a bit dicky, when u press down u can hear the motor whining but nothing happens! Also, I cant control the passenger side window with drivers side control? The passenger side door definately works. Does anyone have any ideas of what the problem is? ?!
  • 2 months later...
Sounds like the cable has broken in the drivers one. It gets used the most and the single drive wire eventually fails. If there is lots of noise and no movement you probably need a new slider/cable mechanism. You can buy this seperately for about 70 quid from VW or look for a scrappy. I prefer to get new for these as you can see lots of peeps have window issues.
Take the door card and liner off and have a look. Boy I hate that job.
The passenger one sounds like a loose conection, especially as the local switch works fine.
