theflyingplumber 0 Posted July 28, 2012 Report Share Posted July 28, 2012 hi need your helpbuilt a track car its had new wheel bearings,trackrods,ball joints anti roll bar brop links it has coil overs and fully poly bushed its been on the road for a month and now seems to have a bit of a time delay on the steering when you turn It turns ok then it turns a little more after its like the rack is moving i have spanner checked every thing tyre pressure are the same both sides i havent had it tracked as i havent foun a setting yet but its been ok for 300 miles it runs on 16" with 195 x 45 tyres any idears thanks Link to post Share on other sites
legvw 0 Posted July 29, 2012 Report Share Posted July 29, 2012 Sounds like it needs the tracking setup. Link to post Share on other sites
Daverse 175 Posted July 29, 2012 Report Share Posted July 29, 2012 As said, I would have the tracking done and have it aligned, as all that work done to the steering and suspension will knock it out a fair bit. Link to post Share on other sites
theflyingplumber 0 Posted July 29, 2012 Author Report Share Posted July 29, 2012 thanks guys any body know of a good set up caster camber toe the car has been lowered and stripped out only got a cage and two seats its on 16` with 205 888s Link to post Share on other sites
bungy 2 Posted July 29, 2012 Report Share Posted July 29, 2012 It would be worth getting a base setting on a 4 wheel alignment machine. Once "true" you can then see how the car behaves and adjust depending on how it reacts. Link to post Share on other sites
theflyingplumber 0 Posted August 4, 2012 Author Report Share Posted August 4, 2012 thanks to all had tracking caster camber set still had the same prob so changed the rack and then re set up all sorted sticks like glue thanks again Link to post Share on other sites
