MarkGolf 6 Posted March 31, 2005 Report Share Posted March 31, 2005 Had a go last weekend, but gave up after 2 mins..Undone the 4 bolts holding the whole rail on, then wanted to pull the whole thing out..Is it a case of a yanking it off?Will I have to replace the seals?cheers Link to post Share on other sites
mightyvr6 0 Posted March 31, 2005 Report Share Posted March 31, 2005 Try twisting them and if that doesn't work, rip them out. Basically they're just a tight fit.Seals only need replacing if they are damaged or perished. Link to post Share on other sites
MarkGolf 6 Posted March 31, 2005 Author Report Share Posted March 31, 2005 Oky sokecheersWill get new seals for sake of it Link to post Share on other sites
DundeeDub 0 Posted March 31, 2005 Report Share Posted March 31, 2005 i had this problem too, just didn't want to pull too hard incase i broke something, you just need to pull and twust though and they will come off.i had the whole lower manifold off the car and found if worked if you started at one end of the fuel rail and pulled while holding the manifold with your feet then get some gloves and pull each injector out while the lower manifold is being push with you feet.you'll find you own technique prob but thats they way i did it Link to post Share on other sites
