Moochalargo 0 Posted June 12, 2012 Report Share Posted June 12, 2012 Hi guysI had a cracked block after cooking it when the serpentine belt went. After 4 rebuilds I got another engine. Rebuilt it and got it running only to be a new member to the red arrows with smoke pooring from the rear. Did new rings and shells and started it again to clouds and clouds of smokeBut after a while it started to clear. I took it for a drive and it feels very retardedWhen I tried to time it up it had no notch on the pully wheel to denote tdc timing. How do I change the timing now it's retarded. I can't face removing the head againPlease help Link to post Share on other sites
cabrioman 6 Posted June 12, 2012 Report Share Posted June 12, 2012 there is a tab on the clutch that should line up with the pointer in the top of the gearbox, fyi when the engine is timed up correctly its NOT at TDC,there is a guide in the premium members section how to check the timing, if the timing is out you will need to remove the upper chain cover and adjust it that way unless its out on the bottom then the gearbox will need to come off .... Link to post Share on other sites
Moochalargo 0 Posted June 12, 2012 Author Report Share Posted June 12, 2012 Oh also when driving or running if the engine is accelerated the oil light comes on and the buzzer goes off like a nut Link to post Share on other sites
Moochalargo 0 Posted June 13, 2012 Author Report Share Posted June 13, 2012 Seems to set the buzzer off at 2500 ish rpm. Oil is brad new and fine and up to level. Oil pump working well. What can this be? Link to post Share on other sites
VeeRsix 0 Posted June 17, 2012 Report Share Posted June 17, 2012 Could be a false positive on the oil pressure switch m8 check this out first, but also do get a second opinion on your pump pressure or we all know what the outcome will be.Good LuckHope you sort itStephen Link to post Share on other sites
