LEMBOT 0 Posted May 10, 2012 Report Share Posted May 10, 2012 Car won't start... Put a code reader on it and no codes? Checked the fuel going into the fuel rail no fuel is coming out? The car cranks just won't fire up, could the pump be fubard? Please help don't want to get the bus! Link to post Share on other sites
legvw 0 Posted May 10, 2012 Report Share Posted May 10, 2012 Might be the fuel pump relay. Have you got a spark when cranking? Link to post Share on other sites
LEMBOT 0 Posted May 10, 2012 Author Report Share Posted May 10, 2012 Not checked that yet my spark plug socket wouldn't fit! If there's no spark when I check could it be ecu issues? Link to post Share on other sites
legvw 0 Posted May 10, 2012 Report Share Posted May 10, 2012 Not ecu, more likely fuel pump relay. Link to post Share on other sites
russj249 2 Posted May 10, 2012 Report Share Posted May 10, 2012 Not ecu' date=' more likely fuel pump relay.[/quote']How about ECU switch relay? That operates before the fuel pump relay. And if its OBD1 they are a mechanical type relay rather than the later type electronic relays.Basically check out relays 167 for the fuel pump, and 109 for the management. Get the fuse box down and turn ignition on and try to feel if they click.Just a though, has it got an aftermarket immobiliser or just standard? Link to post Share on other sites
LEMBOT 0 Posted May 11, 2012 Author Report Share Posted May 11, 2012 Cheers I'll try that so if they click they're working? as far as I'm aware the car hasn't got an immobiliser. Link to post Share on other sites
russj249 2 Posted May 11, 2012 Report Share Posted May 11, 2012 If you can hear them click, and feel them click, its a good indication, but they can still click and be faulty. Have a go and let us know of the results, also test to see if you have spart too as said above. Link to post Share on other sites
LEMBOT 0 Posted May 11, 2012 Author Report Share Posted May 11, 2012 Right then swapped the relay#18 to the fuel relay and it fired up first go, drove it round the block then it died when I got back home. Checked the fuses and the fuel pump fuse had blown soooooo replaced the relay again and it fired up then died after idling for a minute or so.It keeps blowing the fuse any idea's whats causing it? Link to post Share on other sites
russj249 2 Posted May 11, 2012 Report Share Posted May 11, 2012 Could be a wire to the fuel pump shorting out somewhere, or the fuel pump itself shorting out. Take up the boot carpet, and remove the blanking plate with 3 screws in. That will give access to the top of the fuel pump sender. Have a quick look for any damaged wires going through the hole, and any damage to the plug.It way be worth checking if you have continuety down the pump wires, if you have any wires connected to ground other than the earth wire, you have a wire problem somewhere. Link to post Share on other sites
paceo 22 Posted May 11, 2012 Report Share Posted May 11, 2012 ive got a fully working fuel pump relay from russ if you want one?? Link to post Share on other sites
