rsweeney 40 Posted March 13, 2012 Report Share Posted March 13, 2012 noticed i can lift steering wheel up and down slightly and pull it out towards me and push it in again.what bolts are loose ?there is no play in the steering so i was sure its securing bolts ? Link to post Share on other sites
lee123d 0 Posted March 14, 2012 Report Share Posted March 14, 2012 check the whole steering column just take the surround off and you should be able to see if there is any movement anywhere then ul know Link to post Share on other sites
rsweeney 40 Posted March 15, 2012 Author Report Share Posted March 15, 2012 cheers just looked at it and the clamp that secures ignition barrel etc to steering column is slightly loose!how the f*** do i fix that cause the clamp cant be tightened as the bolt on it hasnt got a head.please help ! Link to post Share on other sites
