daveyboy 897 Posted February 3, 2012 Report Share Posted February 3, 2012 Alrite guys, I hope someone can help. ive got a miss on my VR at low revs but once you get the revs passed 2k the miss goes. if you give it a bit grief then stop at a set of lights or something and pull away again the miss is back but worse and sounds like its back firing through the air filter. I just want to try and pin point the problem before i star throwing money at it. and it'll also keep the wife happy that im not sinking all our money into just a car hahaha Link to post Share on other sites
Biggazvr6 0 Posted February 3, 2012 Report Share Posted February 3, 2012 I had the exact same issue with mine. I changed everything on mine so spent quite a bit, all new parts aswell.I changed MAff, lambda, coil pack leads and crank sensor. Still no better in anyway with all these changed. I then bought a new cam sensor, and it cured it. I reackon yours will be the same as your symptoms sound the same as mine. Where are you located mate? Link to post Share on other sites
daveyboy 897 Posted February 3, 2012 Author Report Share Posted February 3, 2012 Cheers mate I'll give that a go. I'm in Newcastle mate. I just didn't think it would be plugs leads or maf Link to post Share on other sites
Biggazvr6 0 Posted February 4, 2012 Report Share Posted February 4, 2012 Make sure you get a genuine vw one as I've heard the cheaper ones aren't worth a w**k. I think mine was 40 odd quid from tps, or find someone off here near you and try before you buy so to speak. Link to post Share on other sites
daveyboy 897 Posted February 5, 2012 Author Report Share Posted February 5, 2012 I'll try that mate there's a few lads in my area so I'll give them a shout. Thanks again Link to post Share on other sites
Biggazvr6 0 Posted February 7, 2012 Report Share Posted February 7, 2012 Did you manage to sort your issue out? Link to post Share on other sites
daveyboy 897 Posted February 7, 2012 Author Report Share Posted February 7, 2012 I haven't had a chance yet mate the VR is my second car so it's not getting used at the moment I'm busy getting it prep'd for paint for GTI this year. There's a lad breaking a Obd 2 engine and box on here so I think I'll try him for the part first and see if that sorts it Link to post Share on other sites
