hi lads!
Right today i was driving my vr and its been making a weird noise for a while!
i removed the 57i a bit ago to try and listen to the noise more
today the car made a squeeling belt noise then spat the belt!!
i had to drive it for a bit! oil temp went to 160 by the time i could stop the car! it shat its coolant and the battery is dead!!
i got towed home and the engine still runs so hoping ive not fucked it!!
anyone have a rough idea how wrecked it may be or will i be lucky?
how hard is a water pump to replace??
cheers lee
  • 1 month later...
Ok ended up having to replace head and gasket ect
But then after when a should have been good I got loads of cream in the header tank shed loads so I cleaned out and flushed with all kinds of stuff and ended up with clear water. After driving for another 20 to 30 miles I now have oil that looks like white coffee and oil in the water again!!!! Agggh
So today I've taken the head off and even though it's supposed to be fine im getting it skimmed and another head gasket set and bolts but some one said the oil cooler may be broken!! Guys do you know or should I roll the car over a cliff somewhere?
