lee123d 0 Posted January 25, 2012 Report Share Posted January 25, 2012 hi all im after some major help i have a vr6 OBD1 and its overfueling its done 157,000miles and had a full headgasket change at 143,000 miles port and polished head and the lambda sensor was done then and ive recently done the engine management sensor that goes in the water flange and put a 4bar fuel regulator on it. when i try starting it when its cold it takes a little time before it starts and then hunts until its warm it stinks of fuel and has black suity stuff in the backbox any help would be appreciated cheers Link to post Share on other sites
craggsy 91 Posted January 25, 2012 Report Share Posted January 25, 2012 I'd look at the MAF. Link to post Share on other sites
lee123d 0 Posted January 25, 2012 Author Report Share Posted January 25, 2012 how do i know if the maf is causing the problem as i cant tell if it is playing up cheers Link to post Share on other sites
filtee 0 Posted January 25, 2012 Report Share Posted January 25, 2012 Unplug it and see if it makes a difference.If it does its obviously working. If not, i'd say its brokenededed Link to post Share on other sites
craggsy 91 Posted January 25, 2012 Report Share Posted January 25, 2012 I don't think obd1 cars run at all without the maf connected. But you can try what is said above Link to post Share on other sites
lee123d 0 Posted January 25, 2012 Author Report Share Posted January 25, 2012 cheers ill try that 2mo and see how it gets on Link to post Share on other sites
russj249 2 Posted January 25, 2012 Report Share Posted January 25, 2012 I don't think obd1 cars run at all without the maf connected. But you can try what is said aboveThey do, but super tricky to pull away from a stand still without stalling and no throttle responce at all.. had it all when mine packed up. Link to post Share on other sites
lee123d 0 Posted January 25, 2012 Author Report Share Posted January 25, 2012 just unplugged the maf and it started but had to keep revs up took my foot off the throttle and it cut out Link to post Share on other sites
ashmk3 0 Posted January 25, 2012 Report Share Posted January 25, 2012 After I did my conversion my car would start then immediacy cut out, then sometimes it would run and hunt. I traced it down to broken maf wires. Fixed the wires and it now runs. Link to post Share on other sites
filtee 0 Posted January 25, 2012 Report Share Posted January 25, 2012 just unplugged the maf and it started but had to keep revs up took my foot off the throttle and it cut outDoesnt sound like its the maf then if it would tickover before. Try and find some one local with a maf you could try. If it is maf, then try cleaning it. Electrical contact cleaner i think. Just take the maf off and spray the thin contacts. Spray lots then let it dry propeprly. Link to post Share on other sites
ashmk3 0 Posted January 25, 2012 Report Share Posted January 25, 2012 Also check the throttle positions sensor. Link to post Share on other sites
michael5556 247 Posted January 25, 2012 Report Share Posted January 25, 2012 I used carburettor cleaner to clean mine. Worked a treat. Link to post Share on other sites
filtee 0 Posted January 25, 2012 Report Share Posted January 25, 2012 Thats what i used but most people have said its too harsh. I wouldnt know cos mine needed replacing as the carb cleaner did nothing. Or maybe thats why it needed replacing. hhhmmmm. Link to post Share on other sites
lee123d 0 Posted January 25, 2012 Author Report Share Posted January 25, 2012 ill give that a try and check the wires cheers Link to post Share on other sites
lee123d 0 Posted January 25, 2012 Author Report Share Posted January 25, 2012 just been googling and it says it could be my o2 sensor as its common it could be burnt out has anyone had this happen to them cheers guys will check wires and get cleaner Link to post Share on other sites
filtee 0 Posted January 26, 2012 Report Share Posted January 26, 2012 Id try the maf thing and then look at the lambadadbaba sensor, aka o2 sensor. Link to post Share on other sites
lee123d 0 Posted January 26, 2012 Author Report Share Posted January 26, 2012 maf seems to be working ok but still going to try another 1 when i see my mate is it average to get 22miles to a tenner as thats what what im getting cheers Link to post Share on other sites
craggsy 91 Posted January 26, 2012 Report Share Posted January 26, 2012 Thats about 13mpg give or take.It depends how heavy your right foot is but you should get 20+mpg all the time Link to post Share on other sites
lee123d 0 Posted January 26, 2012 Author Report Share Posted January 26, 2012 sometimes is very heavy lol but most days i keep to the basic pace cheers Link to post Share on other sites
yakuza racer 16 Posted January 30, 2012 Report Share Posted January 30, 2012 just unplugged the maf and it started but had to keep revs up took my foot off the throttle and it cut outmine is currently doing the same.... will change up leads, thanks mate! Link to post Share on other sites
lee123d 0 Posted January 31, 2012 Author Report Share Posted January 31, 2012 let me know how you get on with yours ive done leads had no change Link to post Share on other sites
