Engine Under Cover Question
Hi guys I've been havin a problem in the wet when I drive through (unavoidable) puddles my spark plugs must get wet cos they just click (I'm guessing shorting with the wet) and my vr runs like a tractor untill I leave her for a while then she's fine so with that was woundering if the vr6's came with a engine under cover cos the vw garage told me it was only the mk 3 desial that had them and if so I'm guessing it would still fit my chassie. any advice or info on keepimg my spark plugs dry or engine under cover would be much appricated.
Thanks Dee
No engine covers, however your issue point more to damaged spark plug leads or a damaged coil pack.
Test 1, at night when it is playing up, have a look down the spark plug holes and watch out for any sparks arcing out to the head.
Test 2, follow the leads back to the coilpack, do a visual test of the coilpack to see if there are any cracks in the resin bits (not the actual plugs where the leads push onto) if there are cracks, then this could also be an issue in the wet.
Failing no weather to test it in, fill up an ordinary kitchen, bathroom cleaner spray bottle with clean water, and spray a very light mist over the coil pack and leads and watch out for any sparks, and listen for it cracking.
