OBD2 1996 VR6 doesn't crank - any ideas?
been parked up two weeks and now won't crank, while i hold the key in the crank position theres a frantic clicking noise comming from behind the dash, almost like a relay clicking but the sound is comming from above the clutch pedel area, not the fusebox.
The lights dont dim or nothing when holding the key to crank so i'm fairly sure its not the battery.
The fuel pump doesn't prime either, so i'm ruling out a starter motor fault, possibly immobiliser issue? i've tried the other key but still the same. car has a laserline (i think) alarm & immobiliser that was fitted about 7 years ago.
i've had the same thing happen twice before aswell, once about a month ago and then about two years before that. but it's always started after about ten minutes ? and i've never been able to pinpoint the exact cause!
any ideas where to start?
