electrical help required
Fuse No. Description Ampere Rating
1 Headlight, low beam, left 10
2 Headlight, low beam, right 10
3 Instrument panel lights, license plate lights 10
4 Glove compartment light, rear wiper 15
5 Wiper/washer 15
6 Fresh air blower, Air conditioning 20
7 Rear light, sidelight, right 10
8 Rear light, sidelight, left 10
9 Rear window defogger 20
10 Fog lights 15
11 Headlight, high beam, left, High beam indicator light 10
12 Headlight, high beam, right 10
13 Horn, 16-valve only: Radiator cooling fan 10
14 Reverse lights, heated washer jets 10
15 Engine electronics, stabilizer valve, cold start valve 10
16 Instrument panel warning lights, MFA 15
17 Hazard switch, indicators 10
18 Fuel pump, oxygen sensor heater 20
19 Radiator cooling fan, air conditioning 30
20 Brake lights, cruise control 10
21 Interior lights, dash clocks, boot light, central locking 15
22 Radio, cigarette lighter 10
Relay No. Description
1 Air conditioning
2 Rear Wiper
3 ECU relay
4 Load reduction/x-over relay
5 Low coolant level control unit or Open
6 Emergency flashers
7 Headlight washers
8 Intermittent wipers
9 Seat belt/lights on warning relay
10 Fog lights
11 Horn
12 Fuel pump (fuel injection) Glow plugs (diesel)
13 Radiator cooling fan after run (except 16-valve) 2.0 16-valve: Starter interlock relay
14 Automatic gearbox, coolant temperature indicator, starter interlock relay (except 2.0 16-valve) 2.0 16-valve: Radiator cooling fan after run
15 ABS pump relay
16 ABS relay
17 Heated seat control unit, driver
18 Heated seat control unit, passenger, or Electric seat circuit breaker
19 Automatic gearbox
20 Open
21 Electric window relay, ABS hydraulic pump fuse
22 ABS valves fuse
23 Air conditioning, power seat fuse
24 Electric window fuse
Connections and plugs on rear of fuse/relay panel:
A1 Yellow 8 pin Headlight wiring harness
A2 Yellow 8 pin Headlight wiring harness
B Green 6 pin Headlight washer wiring harness
C Yellow 8 pin Headlight or wiper motor wiring harness
D Green 12 pin Miscellaneous equipment, varies (A/C, A/T, heated seats, seat belt warning, etc.)
E Green 5 pin Instrument or brake light wiring harness
F White 10 pin Engine compartment/engine management, wiring harness, right side (position 10 open)
G1 White 12 pin Engine compartment/engine management, right side
G2 White 12 pin Engine compartment/engine management, right side (position 12 open)
H1 Red 10 pin Steering column switch wiring harness
H2 Red 8 pin Steering column switch wiring harness (position 8 open)
J Red 10 pin Steering column switch wiring harness
K Black 12 pin Rear wiring harness
L Black 8 pin Rear/Parking brake wiring harness (position 8 open)
M Black 6 pin Rear/fuel tank wiring harness
N Green 6 pin Air conditioning wiring harness
P Blue 10 pin Rear window defroster/fog light wiring harness
Q Blue 6 pin Fresh air blower fan wiring harness (position 10 open)
R Blue 10 pin Light switch wiring harness
S White 5 pin Engine compartment/wiper motor wiring harness, right side
T Green 2 pin Individual circuits
U1 Blue 14 pin Instrument cluster wiring harness
U2 Blue 14 pin Instrument cluster wiring harness
V Green 4 pin Steering column switch Multi-function indicator wiring harness
W Green 6 pin Miscellaneous optional equipment, varies with vehicle type
X Green 8 pin Warning lamp wiring harness
Y n/a 1 pin 4 single point connectors for terminal 30 circuit (some may be bridged with red connector)
Z1 n/a 1 pin Single point connector
Z2 n/a 1 pin Single point connector for terminal 31 circuit
30 n/a 1 pin Single point connector for terminal 30 circuit (may be bridged to 30B with red connector)
30B n/a 1 pin Single point connector (may be bridged to 30 with red connector
Golf MK3, CE2 Fusebox:
A1
1 - yel/wht - left headlight pin 2 (dipped beam)
2 - blk/wht - front left indicator, alarm system control module pin 1, dash plug pin 22 (left indicator light)
4 - gry/blk - front left indicator & parking lights
5 - red - rad fan thermal switch pin 3
6 - wht/blk - left headlight pin 1 (main beam)
7 - blk/yel - horn(s) pin 2
8 - brn/blk - horn(s) pin 1
A2
2 - front right indicator & parking lights
3 - yel - right headlight pin 2 (dipped beam)
4 - blk/grn - front right indicator, alarm system control module pin 2, dash plug pin 24 (right indicator light)
7 - wht - right headlight pin 1 (main beam)
8 - gry/yel - rear fog lights
C
1 - blu/brn - brake fluid warning switch pin 1
2 - grn/red - washer motor pin 1
7 - brn/blu - washer motor pin 2
8 - blu/red - coolant level sensor pin 2
D
3 - blk/red - glovebox light pin 2
8 - blk - ignition coil, ECU pin 38, vehicle speed sensor pin 1, Junction connector TV4, airbag control unit pin 12
9 - blk/wht - Junction connector TV5
11 - blk/blu - Junction connector TV5
12- gry/blu - Junction connector TV8
E
2 - blk - Junction connector TV4
3 - blk/red - brake light switch pin 1
4 - red/yel - brake light switch pin 2
F
1 - red - alarm control unit pin 5, ECU pin 7, park/neutral position switch, starter motor pin 50
3 - blu - alternator pin D+
4 - brn - vehicle speed sensor pin 3
6 - blk/red - reverse light switch pin 2
- blk - Park/Neutal position relay pin 5
7 - blk blue - reverse light switch pin 1
G1
2 - brn/wht - outside air temp sensor
3 - yel/blu - ECU pin 6
4 - blk - ECU pin 38, gearbox speed sensor, ignition coil pin 3
5 - brn/wht - earthed to engine block
6 - brn - heated washer jets
- brn/red ECU pin 12 (1.8L)
7 - blk/brn - ECU pin 9
8 - red/yel - lambda probe pin 2
9 - yel/blk - ECU pin 5
10- red/blu - ECU pin 23, cam position sensor pin 3, evap canister purge valve, maf sensor pin 3, lambda probe pin 6, EGR valve, fuel injectors
11- wht/blu - vehicle speed sensor pin 2
12- grn/blk - ECU pin 22
G2
1 - grn/blk - oil temp sensor
2 - wht/red - outside air temp sensor
3 - blu/wht - coolant temp sender
4 - blk/pur - ECU pin 38 (ABF), carbon canister, isv, breather heater
10- yel - high oil pressure warning switch
11- blu/blk - low oil pressure warning switch
H1
1 - red/blk - ignition switch pin 50
2 - red - ignition switch pin 30
3 - blk/yel - ignition switch pin X
4 - blk - ignition switch pin 15
5 - blk/blu - indicator stalks 4pin plug pin 4
6 - brn - wiper stalk 4pin plug pin 3
7 - brn/red - ignition switch pin S, radio pin 4
8 - grn/red - wiper stalk 4pin plug pin 2
9 - grn/wht - wiper stalk 4pin plug pin 1
H2
1 - brn/blu - indicator stalk 7pin plug pin 1
4 - blk/grn - indicator stalk 7pin plug pin 7
6 - blk/wht - indicator stalk 7pin plug pin 3
8 - blk/wht/grn - indicator stalk 7pin plug pin 2
J
1 - wht - indicator stalk 5pin plug pin 4
2 - wht/blk - indicator stalk 5pin plug pin 3
3 - yel - indicator stalk 5pin plug pin 2
- yel/blu - DRM relay resistor?
4 - red/yel - indicator stalk 5pin plug pin 5
5 - grn - wiper stalk 5pin plug pin 3
6 - brn/blk - wiper stalk 5pin plug pin 5
7 - blk/gry - wiper stalk 5pin plug pin 2
8 - wht/yel - indicator stalk 5pin plug pin 1
9 - grn/blk - wiper stalk 5pin plug pin 4
10- grn/yel - wiper stalk 5pin plug pin 1
K
1 - blk/wht - rear left indicator
2 - gry/red - right rear lights
3 - gry/blk - left rear lights
4 - red/blk - brake lights
5 - gry/grn - rear number plate lights, rear ashtray light
6 - blk/yel - rear wiper motor pin 1
7 - blk/grn - rear right indicator
8 - blk/blu - reverse lights
9 - grn/blk - rear wiper motor pin 3
11- brn - rear ashtray light, 'earth claw'?
12- wht - rear screen heater
L
1 - brn - handbrake warning switch pin 2
2 - gry - left door switch pin 1
4 - blk/grn - left seatbelt switch pin 1
5 - red/blk - boot light
6 - brn - handbrake warning switch pin 1
- ? - DRL diode
7 - red/blk - electric sunroof control module pin 5, sunvisor mirror light, front & rear interior lights, central locking control module pin 1
M
1 - brn - fuel pump
2 - red/yel - fuel pump
3 - vio/blk - fuel level sender pin 2
5 - blk/wht - sunroof light switch pin 1, right front map/reading light
P
1 - gry/yel - fog light switch pin 83a
2 - blk/yel - rear window heater switch pin 4
3 - wht/grn - rear window heater switch pin 3, heated mirror elements
4 - gry/blu - fog light switch pin 83
5 - brn - rear screen heater switch pin 31
7 - gry/blu - rear screen heater switch pin 1
Q
1 - brn - glovebox light pin 1, boot light pin 2, cigarette lighter pin 1, A/C switch pin 3, blower light pin 2, diagnostics plug pin 1, boot release switch pin 2
2 - blk/red - bridged to N/6, Blower switch pin 2, coolant control module 8pin plug pin 4, A/C thermal switch/engine coolant temp warning switch pin 2
3 - red/wht - cigarette lighter pin 2, radio pin 7, boot light switch pin 1, diagnostic connector pin 2, boot release switch pin 1
6 - gry/blu - blower switch pin 1, A/C switch pin 5, cigarette lighter pin 3, radio pin 6
R
2 - gry/blk - headlight switch pin 58L
4 - brn - headlight switch 58b
5 - red/yel - headlight switch pin 11
6 - gry/red - headlight switch pin 58R
7 - gry/grn - headlight switch pin 58
8 - brn - headlight switch pin 31
9 - wht/blk - headlight switch pin 2
10- blk/yel - headlight switch pin X, DRM relay pin 4
S
1 - blk/gry - wiper motor pin 1, heated washer jets
2 - grn - wiper motor pin 4
3 - brn - wiper motor pin 5
4 - grn/blk - wiper motor pin 3
5 - grn/yel - wiper motor pin 2
U1
1 - wht - Dash plug pin 17 (oil temp sensor)
2 - wht - Dash plug pin 19 (outside temp sensor)
3 - wht - Dash plug pin 8 (oil pressure control unit - feed from 1.8 bar)
5 - wht - Dash plug pin 9 (oil pressure control unit - feed from 0.3 bar)
6 - wht - Dash plug pin 10 (rev counter)
7 - wht - Dash plug pin 1 (outside temp sensor)
10- wht - Dash plug pin 3 (earth)
11- wht - Dash plug pin 27 (speedo signal)
12- wht - Dash plug pin 21 (fuel gauge)
14- wht - Dash plug pin 12 (dash & digital clock bulbs)
U2
1 - wht - Dash plug pin 13 (ignition live feed)
2 - wht - Dash plug pin 7 (cruise control unit pin 5, 2.0 16v motronic control unit pin 2?)
4 - wht - Dash plug pin 15 (stalk memory switch pin 2)
5 - wht - Dash plug pin 2 (coolant low level sender)
7 - wht - Dash plug pin 25 (main beam warning light)
8 - wht - Dash plug pin 6 (stalk memory switch pin 3)
9 - wht - Dash plug pin 23 (coolant temp gauge)
10- wht - Dash plug pin 18 (handbrake warning light)
11- wht - Dash plug pin 11 (permanent live feed from fuse #21)
12- wht - Dash plug pin 16 (alternator warning light)
13- wht - Dash plug pin 5 (earth to cylinder head)
14- wht - Dash plug pin 4 (stalk memory switch pin 4)
V
1 - red/wht - MFA mode select switch
2 - brn/wht - MFA switch earth
3 - blu/yel - MFA switch memory select/reset
4 - yel/red - MFA switch memory select/reset
W
1 - blu/wht - vehicle speed sensor junction connector
2 - gry/blk - ABS relay pin 3, ABS module pin 52
4 - wht/red - ABS module pin 32
- blk/red - Cruise control clutch & brake pedal switch pin 1, transmission control module pin 26
X
2 - blk/yel - airbag control light pin 4, ABS warning pin 2
4 - blk/yel - airbag control light pin 2
8 - yel/red - ABS warning light pin 1
Y
1 - brn/blu glow plug timer module pin 5
2 - electric windows, park/neutral psition relay pin 2
3 - Red - Battery +ve, Junction connector TV2
Z1 - red/blue - fuel injectors
Z2 - brn - battery -ve
Junction connector TV2: (Permanent live feed direct from battery - 30)
Y/3
alarm control module 6pin plug pin 3
alarm control module 10pin plug pin 1
left/right central locking trigger motors pin 2
alarm/central locking/boot lock switch pin 4
alarm system indicator light pin 2
left/right door warning lights pin 2
ECU pin 54
fuel evap relay pin 2
Junction connector TV4: (Ignition live, from coil -15)
E/2
D/8
alarm module 10pin plug pin 4
shift lock solonoid pin 2
transmission control module pin 19
cruise control/transmission range switch pin 5
Airbag control module pin 5
cruise control range switch pin 5
Transmission control module pin 23
Junction connector TV5: (Ignition live, from coil -15)
D/9
D/11
cruise control/transmission range switch pin 4
left/right rear electric window switches pin 1
A/T console light
cassette storage light
transmission control module pin 38
electric mirror switch pin 6
heated seat switch pin 3
heated seat control modules pin 8
electric window control modules pin 7
PCV heater
Junction connector TV6: (Ignition live, from x-over relay -X)
D/3
Coolant fan control module T10a/9
3rd speed coolant fan switch pin 2
A/C pressure switch pin 4
Junction connector TV8: (Dash lights feed)
D/12
heated seat switch pin 1
electric mirror switch pin 2
front electric window switches pin 1
electric window switch console pin 4
cruise control transmission range switch pin 4
A/T console light
Junction connector TV11: (Brakes on feed)
W/4
Diesel DFI ECU pin 44
Junction connector TV13: (Vehicle speed sensor)
W/1
cruise control module pin 7
ECU pin 65
Junction connector TV15:
left door warning light
left door contact switch
Junction connector TV18: (Ignition live, from x-over relay -X)
D/3
ABS control module pin 23
Diagnostics junction box 1: (Transmission control Diagnostics feed)
ECU pin 21
Diagnostics junction box 2: (ECU Diagnostics feed)
diagnostics plug pin 2
ECU pin 43
transmission control module pin 6
ABS control module pin 42
Hope this helps
right the front of the fusebox looks fine to me . the connectors in the pictures, the first picture (red connector .Black/red wire) im sure is the radio feed that goes dead when you pull the key out, the next one im not 100% sure about, the next one (green connector, black/white wire) goes to the green connector block that sits behind the drivers side vent. the next 2 connectors , grey /brown. im sure they are left disconnected. the next one i am unsure of, the black connector below LOOKs like the wire colours for the washer jets.the next few connectors im sure there are plugs for them behind the dash, they are colour coded,and the final connector (red with red/yellow cable) connects to one of the pins at the top of the fusebox,its difficult to say without actually being there to trace wires :( fuse 21 is for the interior lights etc, so its possible you have a connector in the wrong place on the back of the fusebox, did you check it against the diagram i gave you?
sweet thats one sorted out. fuse 21 is 15 amp and feeds interior lights/boot light/central locking etc. it is connected to Conecctor L Pin 7. red/black cable . im wandering if that red and black cable with red connector (the first picture) is linked into the radio and ignition wiring, which is why your lights are staying on . check the back of the fusebox and make sure the wire colours are correct for connector L . hope this helps.
