VDO Oil Pressure Gauge + Sender
the senders come with different low pressure warning points built in, you just need to get the correct one.
i got mine from here http://www.etbinstruments.com/index.htm rang the man up and he asked me what low pressure point i needed, 0.5 being the lowest you can get.
Just had a look at my receipt, no its not cheap, the sender was £50, i looked for a part number but it didnt list one
Hey Luke is there a reason why it the sender has to be as low as 0.5 bar?
The reason I ask is that I have found one that is at 12psi - 0.8 bar for good money as in cheap lol. I found that chap and you are right its expensive.
Will this effect the low pressure sensor for the ecu?
Decided not to go with the one of ebay and am looking at this website as its cheaper but I think it ticks the boxes
http://shop1.actinicexpress.co.uk/shops/partsforaircraft/index.php?cat=VDO_Sensors
360-023 150psi /10 bar Metric M10 x 1 thread
Twin terminal, second terminal is for a low pressure warning lamp triggered below 7 psi.
30/9 stamped into the nut
Ground is via the engine block.
Price: £46.80 £39.00 (Excl. VAT) + £2.81 P&P
