Supercharging Issues - Updated
  • Replies 173
  • Created
  • Last Reply
Top Posters In This Topic
Sorry guys its just to damn dark!
In the meantime I have email VF-Engineering technical department for the part number for the injectors
Thats correct craig, I have tried both unplugged and plugged in MAF to see how the car performs and its the same.
is the flow the right direction ??? not sure it would give the faults you are getting thou ???!!
The arrow is pointing in the right direction for sure. Away for the air filter side but I will check that again tomorrow including the silicone joiner!
How does it run when you accelerate?
Stays rough like at idle?
Ah......I haven't actually taken it out for a drive yet.
Actually just thought of something else. I got Tony to fit some Schimmel 263 cams and a Walbo inline fuel pump in on Saturday.
I checked the cabling and cleared the errors, ran again and no errors but she still runs like a dog!!!
I changed the silicone hoses for better fittings ones and that's made a huge difference to the fittings.
I installed the boost gauge but got no reading when revving to 3000 rpm is this normal?
I had an issue after I had first fitted mine... Ran great and then ruff as a badgers ar$e suddenly. Similar sounding issues to you... was worse under load not revs...
So the solution I hear you ask....
The pipe that connects derectly on to the charger (MAF/Filter side) was not 100% level. This allowed for a small air leak. It took me 3 hours of knuckle losing jiggery pokery but - Eventually with a little triming here and a little trimming there Perfect!!!!
It then ran as good as gold. May not be your issue but hey something else to check ;)
Good luck
