bazz780 0 Posted February 27, 2005 Report Share Posted February 27, 2005 hey guys -anyone have a clue why the fuel pump fuse keeps blowing??am i right to assume its a 20A fuse??cheers Link to post Share on other sites
tommy 0 Posted February 27, 2005 Report Share Posted February 27, 2005 20 amp is right for the pump......you might want to check the fuel pump relay as it might me faulty???? other than that the live feed to the pump is earthing out some where or the pump its self might be at fault.........you can run a separate power lead direct to the pump with a fuse in line to check the pump its self...this will at least pinpoint the problem towards the existing power lead. Link to post Share on other sites
bazz780 0 Posted February 27, 2005 Author Report Share Posted February 27, 2005 cheers will try sort that out asap. Link to post Share on other sites
