Hello i have reacently bought a 98 vr6 and there seem to be a problem when accelerating the car judders, its like trying to go up a hill in the wrong gear!! if in 3rd i constanly need to change to 2nd to accelerate! it seems to get better when the car car is warm?? i have just changed the cam position sensor but its still the same! any thoughts are much appreaciated
It's likely that the plugs are shot, the leads have not been fitted correctly (which i have seen alot) or the coilpack is arcing.
With the engine running, let the bonnet down onto the back of your head (seriously) and look at each of the connections to the plugs and at the coilpack, you will most likely see something arcing out.
If nothing is apparent, use a spray bottle with water and lightly spray it on the ignition system, if there's a weakness the water will make it visible. Try this and let us know how you get on.
It's likely that the plugs are shot' date=' the leads have not been fitted correctly (which i have seen alot) or the coilpack is arcing.
Thanks for the info mate, offshore at the moment but will give it ago when im home in two weeks
  • 4 months later...
