b19drg 0 Posted June 18, 2011 Report Share Posted June 18, 2011 Hi guys , I have a loud clonking noise from the passenger side top mount when I go over any kind of bumps , with the bonnet open if i push the front wing down i can make the clonking noise , there brand new top mounts and bearings only done about 100 miles , any ideas guys also got a nasty wheel wobble could the be related ?? help please as im really losing the love for this car at the moment ! Link to post Share on other sites
bungy 2 Posted June 18, 2011 Report Share Posted June 18, 2011 Are you sure they were fitted correctly mate? Sounds like they have not been done up properly. Link to post Share on other sites
legvw 0 Posted June 18, 2011 Report Share Posted June 18, 2011 It could be something else. like bottom ball joint or anti-rollbar bush/drop link. Top bearings should last longer than 100miles! Link to post Share on other sites
b19drg 0 Posted June 18, 2011 Author Report Share Posted June 18, 2011 just been out to look at the bolts , they seem tight but they spin on the bearing i guess ?? Link to post Share on other sites
b19drg 0 Posted June 18, 2011 Author Report Share Posted June 18, 2011 It could be something else. like bottom ball joint or anti-rollbar bush/drop link. Top bearings should last longer than 100miles! \would any of those cause a wheel wobble ? Link to post Share on other sites
bungy 2 Posted June 18, 2011 Report Share Posted June 18, 2011 Have you tried jacking one side and moving the wheel to see if there is any give or noises like that? Link to post Share on other sites
b19drg 0 Posted June 18, 2011 Author Report Share Posted June 18, 2011 when you push the wing the noise comes from around the top mount, havent jacked it up , will do tomorow Link to post Share on other sites
Gazbarber1982 3 Posted June 18, 2011 Report Share Posted June 18, 2011 Your spring might not be in the locating lug Link to post Share on other sites
