need help with vr6 temp and heater
hi mate
umm il check it tomorrow .. and umm i can feel hot air in vents , but when i choose speed like 1 2 3 etc it doesnt blow any air.
where the thermo housing sensor located? im new to vrs
Sounds like the heater motor isn't working... Check fuse and relay... It could be possible that the motor is dead but cheaper / easier to check fuses etc...
Im pretty sure it's the yellow sensor that controls the temp dial on the clocks...
Bridge terminal A and C with ignition on... If the needle moves, then you know its the yellow sensor at fault..
Do you know if your aux water pump is working as that also is operated from the same switch, you can test that by bridgeing B and D.
The thermostat housing is located on the front right side of the engine, easy to spot as there's 3 sensors usually on it :)
