4motion pipe identification
before i start i must appologise for poor blackberry immages
plz can some one help me id these couple of pipes
ist pipe, connects to the head next to the inlet manifold, it the pipe just above the 7mm hex bolt head
this is the end of it
the other bit of pipe work i need to know about is this one, its sits behind the the inlet manifold by the bulk head
any help with iding them and yetting me know where they go would be much appreciated
The 1st pipe links the cylinder head to the pipe between the MAF and the Throttle body. This is there to feed metered air to the injector shrouds. This not being connected will make the car idle incorrectly.
The 2nd pipe also connects to the big black tube linking the MAF to the throttle body. This takes oil vapour from the crank case and passes it into the inlet tract for it to then be burnt by the engine. Again this not being connected will make the engine idle incorrectly.
