russj249 2 Posted April 7, 2011 Report Share Posted April 7, 2011 Just wondering if a VW sharan 12v head would be compatible with a 12v OBD1 golf mk3 block.I want a head to rebuild but she sharan heads seem to go for less :SJust wondering if there's any difference in them, or if they are all the same? Inc. if they have twin top chain etc.CheersJoe Link to post Share on other sites
UnitedMotorsport 55 Posted April 7, 2011 Report Share Posted April 7, 2011 It works just fine. You will need to block up the secondary air injection port on the front of the head. Link to post Share on other sites
russj249 2 Posted April 7, 2011 Author Report Share Posted April 7, 2011 ok thanks for the quick response. Never knew about that secondary air injection port, so will bear that in mind.anyway, I also noticed there's a lot more OBD2 heads for sale than OBD1's, is it just a case of swapping the timing pulleys over to make it twin top chain, or have the cams or anything else got to be changed? Link to post Share on other sites
UnitedMotorsport 55 Posted April 7, 2011 Report Share Posted April 7, 2011 You can put an OBD2 head on an OBD1 block and vice versa.The cam pulleys are of no consequence, just fit the ones that are right for your engine.Cams for all '174hp' engines are all the same. Link to post Share on other sites
russj249 2 Posted April 7, 2011 Author Report Share Posted April 7, 2011 Perfect! Thanks for the quality information as usual! Will try and get one to rebuild, or one already rebuilt if it's the right money. Link to post Share on other sites
yakuza racer 16 Posted April 7, 2011 Report Share Posted April 7, 2011 today i learnt! Link to post Share on other sites
