Hi got this car with the problem been doing research and iv checked the handbreak "switch" thats ok also disconected the break fluid float and light is still on so did a vag com scan or errors on abs and came back with this
VAG-COM Version: Release 409.1-US
Control Module Part Number: 3A0 907 379 E
Component and/or Version: ABS/EDS ITTAE 20 GI V00
Software Coding: 03704
Work Shop Code: WSC 00000
4 Faults Found:
00285 - ABS Wheel Speed Sensor: Front Right (G45)
35-00 - -
01276 - ABS Hydraulic Pump (V64)
16-00 - Signal Outside Specifications
00290 - ABS Wheel Speed Sensor: Rear Left (G46)
35-00 - -
00287 - ABS Wheel Speed Sensor: Rear Right (G44)
35-00 - -
Can anyone help i guess i need new speed sensors and a abs pump :( also is it safe to drive it like this ???
I would suggest clearing the codes and seeing what comes back before buying bits, but l would think that you will end up replacing the speed sensors :(
it should be safe to drive, but you wont have abs, your brakes should still work fine, if l am wrong someone will be along to correct me :)
I would suggest clearing the codes and seeing what comes back before buying bits' date=' but l would think that you will end up replacing the speed sensors :(
Cleard the codes and they came stright back!!! do you think i need an abs pump or just speed sensors??
hhmm thats never fun :( I would start with changing the sensors and see if that sorts it and if not then start looking at the pump, as l am sure you dont really want to buy a new pump if you dont need it :) but as you appear to need to change 3 of the sensors l would just replace all 4 while your at it :)
I was thinking of just getting rid of abs all togeather lol
that would work too lol
Would i just need to unplug the pump in the engine bay.??
To be honest l am not sure, I would guess it is a simple case of unplugging the pump and sensors ect… but to stop the light coming on you would need to get it mapped out or as above find a dial set to replace it with :)
