paceo 22 Posted March 14, 2011 Report Share Posted March 14, 2011 just changed everything to service my car but the oil filter housing plastic nut is chewed so i cant get it off, any other ways of getting of off?ive tried one of them straps that you tighten over it but it keeps slipping. Link to post Share on other sites
Lukey. 381 Posted March 14, 2011 Report Share Posted March 14, 2011 mole grips? sounds like once youve got it off you want to replace it too. Link to post Share on other sites
paceo 22 Posted March 14, 2011 Author Report Share Posted March 14, 2011 no chance its plastic mate!there must be some sort of large cup type thing i can buy to fit over the dimples on the side of it??? cant find anything on ebay! :-( Link to post Share on other sites
ROBSVENTO 0 Posted March 15, 2011 Report Share Posted March 15, 2011 you wont mate, i have the oil filter set to remove all plastic housings and out of 20 different cups not one fit... i ordered a new one for mine and when it came its got metal inside the plastic on the newer ones so impossible to break..Youll have to get a new one mate and smash ur old one off... Link to post Share on other sites
Lukey. 381 Posted March 15, 2011 Report Share Posted March 15, 2011 Yea does sound like you arent gonna gry it off in a serviceable confition. Would think the easiest thing would be to try and chisel it round or drill holes in it to get some good purchase on it, then try and wrench it off, it should only be on with 30Nm of force so shouldn't be to much grief to get off. Link to post Share on other sites
paceo 22 Posted March 15, 2011 Author Report Share Posted March 15, 2011 you wont mate' date=' i have the oil filter set to remove all plastic housings and out of 20 different cups not one fit... i ordered a new one for mine and when it came its got metal inside the plastic on the newer ones so impossible to break..Youll have to get a new one mate and smash ur old one off...[/quote']cool you got the VW part number for a new one? Link to post Share on other sites
xyber 1 Posted March 15, 2011 Report Share Posted March 15, 2011 Use an old school bike chain style oil filter tool, it'll cut in an grip. Or take the Allen plug out and get the jaws of the grips in the hole and outside on the socket hexagon. They aren't supposed to be tight and have a large thread so you only need to start it, then finish by hand. Taking the Allen plug out will release the vacuum as well and make it easier Link to post Share on other sites
trackday 0 Posted March 15, 2011 Report Share Posted March 15, 2011 i use large water pump pliers when i cant get them off they work fine,http://www.justoffbase.co.uk/Water-Pump-Pliers-500mm-Ni-Fe-Finish-Sealey-AK9371 Link to post Share on other sites
ROBSVENTO 0 Posted March 16, 2011 Report Share Posted March 16, 2011 It will b the same vw number as the one your taking off mate, just ring up ur local parts place n quote the vw number off your old housing.. Link to post Share on other sites
