cornishvr6 52 Posted March 12, 2011 Report Share Posted March 12, 2011 Received a obd2 288mm front brake set up to upgrade from my 280's.They come with original brake hoses with a screw connection on the car end, Im understanding these will be a direct swap as the early car has screw type fittings also?My next question is also supplied is a set of front goodridge brake hoses but these have screw fitting both ends so again im guessing these wont fit the late type caliper?any help is appreciated Link to post Share on other sites
russj249 2 Posted March 12, 2011 Report Share Posted March 12, 2011 Yes the new flexy's will fit straight to the old brake pipe fitting. they are all the same with an 11mm pipe fitting.the later goodrich hoses have the flat banjo fitting with the bolt, so the screw in fittings both ends would be just obd1. Link to post Share on other sites
cornishvr6 52 Posted March 12, 2011 Author Report Share Posted March 12, 2011 Yes the new flexy's will fit straight to the old brake pipe fitting. they are all the same with an 11mm pipe fitting.the later goodrich hoses have the flat banjo fitting with the bolt' date=' so the screw in fittings both ends would be just obd1.[/quote']Thanks for the help mate, Looks like i will have to sell on the goodridge hoses in place of the banjo type fittings then Link to post Share on other sites
