houlahoop 0 Posted January 29, 2011 Report Share Posted January 29, 2011 I've got a 97 OBD2 VR6 with an ABS light that keeps coming on and off (i know how rare that is! lol) VAG COM has given me 01276 as the fault code. Ive read a few threads that point to fuses by the battery, which mine doesnt seem to have, I think they are under the steering column on mine. Because it is intermitent im thinking that its more likely to be the control module rather than the pump or a bad conection some where, but before i pulled it all to bits I wondered if you fine guys and gals on here could shed any light on it or point me in a certain direction. Cheers Link to post Share on other sites
legvw 0 Posted January 29, 2011 Report Share Posted January 29, 2011 It could be 1 of the relays in the abs loom if its intermitent, i doubt its a fuse. Link to post Share on other sites
Ian_rogers 0 Posted January 29, 2011 Report Share Posted January 29, 2011 Give all ur sensors a clean up, been havin similar troubles so cleaned them today n so far all seems good (fingers crossed) Link to post Share on other sites
houlahoop 0 Posted January 29, 2011 Author Report Share Posted January 29, 2011 Thanks guys, im replacing the discs and pads all round, so think ill replace the sensors, bearings seals etc etc whilst im at it, hopefully that'll do it Link to post Share on other sites
VR6-DUB 3 Posted January 29, 2011 Report Share Posted January 29, 2011 Did you have any luck? Link to post Share on other sites
houlahoop 0 Posted January 29, 2011 Author Report Share Posted January 29, 2011 Not got around to doing it yet, I was going to get it done tonight, but then found out that I was wrong, I was going to be plastering the hall way instead, my missus really needs to get her priorities straight!! Link to post Share on other sites
