*P3nfold* 0 Posted January 7, 2011 Report Share Posted January 7, 2011 The vacuum hoses both connect to the black thing, the picture shows it better. Would this cause a problem as I am getting a vacuum leak.Also what is the black thing (not the bottom right) that the two blue silicone hoses connect and what does it do? Link to post Share on other sites
VR6Pete 1,455 Posted January 7, 2011 Report Share Posted January 7, 2011 I don't recall 2 hoses going into the vacuum line! On my schrick one line went into the vacuum, the other went into the solenoid which in turn hooked up to the flap. Never had any leaks. Oy problem I had was a sticky flap! Link to post Share on other sites
VR6Pete 1,455 Posted January 7, 2011 Report Share Posted January 7, 2011 The black thing is the vacuum tank btw. I located mine under the scuttle pannel Link to post Share on other sites
*P3nfold* 0 Posted January 10, 2011 Author Report Share Posted January 10, 2011 Thanks Pete, would it cause a issue the way its been fitted to the vacuum tank?Only other problem I have is the paddle flap is resonating a bit and I need to sort this, trying to get Schrick to tell me the parts needed so I can reverse engineer.Ah do you know what size Vacuum hose is needed? I think roger said 3mm but was not a 100% sure? Link to post Share on other sites
