No compression on 3 firewall side cylinders
Thanks. Does this car have one camshaft for all exhaust valves and one for all intakes?. My thinking is that if he has bent valves, then the timing must have jumped. But if one shaft serves 1/2 the valves on either side of the head why wouldn't it have low compression on all cylinders? Are the piston to valve relationships the same on either side of block?
