mikey 0 Posted December 15, 2010 Report Share Posted December 15, 2010 Could someone pop out to their vr an tell me if their fuel pump primes before turning it over as mine isn't :-( thanks Link to post Share on other sites
Ian_rogers 0 Posted December 15, 2010 Report Share Posted December 15, 2010 Yeah it does mate Link to post Share on other sites
mikey 0 Posted December 15, 2010 Author Report Share Posted December 15, 2010 Great thanks mate Link to post Share on other sites
mikey 0 Posted December 15, 2010 Author Report Share Posted December 15, 2010 Right fuses are all ok wiring good and relays all workin by which I mean if I put power on them they operate but I have noticed that relay 109 and 164 both operate the pump any ideas guys ??? Was working fine before I pulled the engine but not now it's back in but to my knowledge there's nothing under the bonnet which would affect that is there ???? Link to post Share on other sites
Ben Seabrook 4 Posted December 15, 2010 Report Share Posted December 15, 2010 relay 109 is the ECU relay mate Link to post Share on other sites
mikey 0 Posted December 15, 2010 Author Report Share Posted December 15, 2010 So in otherwords the ecu is not getting power ? Link to post Share on other sites
Ben Seabrook 4 Posted December 15, 2010 Report Share Posted December 15, 2010 nah I meant that 164 must be the fuel pump one so thats the one to replace if it's not working - is the car not firing at all then ? have you had it on vag-com ? Link to post Share on other sites
mikey 0 Posted December 15, 2010 Author Report Share Posted December 15, 2010 No haven't got vag com that would make sense tho coz when I operate 109 it all kicks into life so I need to find out why that one isn't getting any juice I wouldn't mind but I haven't even touched any of that !!?!?!? Link to post Share on other sites
Ben Seabrook 4 Posted December 15, 2010 Report Share Posted December 15, 2010 I have found on my old vr that the relays didnt really need a reason to stop working ! where are you in Essex as we have a couple of members there with vag-com Link to post Share on other sites
mikey 0 Posted December 15, 2010 Author Report Share Posted December 15, 2010 I'm in hockey would be great if someone could pop over ! I know what u mean about them just giving up but I have put a supply to them and they are working fine so it must be the supply in the car that's at fault I'm starting to wonder if it's the chip in the key but they are fairly new as well and like I said was fine before do you or anyone else know what controls 109 ?? Link to post Share on other sites
mikey 0 Posted December 15, 2010 Author Report Share Posted December 15, 2010 Yep Definately have no power feeding relay 109 does anyone know where this should come from ??? Link to post Share on other sites
Apollo 0 Posted December 15, 2010 Report Share Posted December 15, 2010 Mikey change the relay before chasing any further you may be surprised it could be that simple. Link to post Share on other sites
Pearsy47 1 Posted December 15, 2010 Report Share Posted December 15, 2010 i got a fuel pump relay if you wanna buy it it is working order ! Link to post Share on other sites
mikey 0 Posted December 15, 2010 Author Report Share Posted December 15, 2010 Cheers guys but it's def not the relay as I have now found that the ecu relay has no feed so I must have done something silly under the bonnet ! Link to post Share on other sites
