i have a 97 golf vr6 air con model, air con worked fine all summer , but now cold snap has hit when i press econ button on climatronic i dont hear the clutch on compressor kick in! in manual it says if ambient temp below 5 degrees it wont work is it fair to say thats what it is? tried to trick system by pouring warm water of temp sensor in lower grill front bumper but that failed to raise temp .
just wondered if anyone else has had this and confirm its just cos of cold snap cheers guys
Pretty sure it's just the cold. I have climtronic too an mine doesn't switch on now either. It's to protect the compressor I believe, something to do with expansion rates and stuff. Hot water wouldn't work but maybe try a fan heater in front of the sensor instead if you want to be sure.
